Front camera not available
IzzatW
Visitor
I'm currently using Sony Xperia C5 Ultra Dual. After I updated my software from 5.0 to 5.1, my front camera is no longer available. It says "Camera not available. Flashlight or Camera may be in use by another application. Close it and try again". I've tried many methods already including factory reset.
56 REPLIES 56
goth2k
Visitor
I'm another user very disappointed, after updating to Android 5.1 my front camera stopped working. I tried everything, 1st using logcat, then full reset and finally Xperia Companion Repair, nothing has fixed the front Camera.
I've  been reading this forum and many others about this problem that many users experience and the only answer Sony is providing, is to send the phone to the support centre. Come on ! I'm sure it's not only myself that think is kinda obvious that the upgrade to 5.1 affected the front camera, so please Sony, instead of asking us to waste our time, fix the problem and release another update. I'm sure you had plenty of users already sending their phones to your service center and you should have a clear idea on how to fix it.
This is not the 1st time I had a problem after and update (check my forum history), so I think before releasing an update Sony should test it properly !!!
Light3
Visitor
Same problem here!! After a software update, the switch camera  icon is missing. I reseted my phone, did a software repair with PCC but nothing worked. Im gong to have my phone checked out by a Sony repair center here in Monterrey Mexico. I'll let you guys know the outcome.
grouchon
Visitor
Yes! I have the shame problem. I've tried everything!!! It doesn't work. I bought it for that camera like you... It's really reply frustrated. Format, restart, everything...
grouchon
Visitor
Somebody knows something? Sony is a disaster. They don't say nothing.
Christofer
Champion
@grouchon If a software repair didn't help you should get your phone examined further at an authorised service center. You can contact your Local support team for more information on how to proceed with this.
IzzatW
Visitor
I started this forum in February and there's still no solution.. I really really really hope that the Marshmallow update helps all of us who shares the same problem
Christofer
Champion
Hi @IzzatW, I'm very sorry to hear that.
I do recommend that you get your device examined by an authorised service center. Your Local support team can help you proceed with this.
Aldo2536
Visitor
When I open the app it tells me " can not récord. Maybe another app is using récord... " I have hard reseted My c5 ultra and the trouble comes back after some period of time, I can take pictures, but can not recording.. I'm boring of this situation... any advince you can give me!
I need help
Macharia
Visitor
Try disabling Google ok
Elhosseny2007
Visitor
This problem is that in my phone 📱
The front camera 🎥 is don't work after update to marshmallow i don't know what's going on.  I'm in Egypt and my phone coming from Saudi Arabia.
What can I do?
