Hi all can anyone tell me why can't I unmount data from my internal memory to my SD card memory after updation of Android new version???
What data are you trying to transfer? Media can be easily transferred by connecting the phone to a PC/Laptop and use simple copy and paste.
Hi, i have the same problem, my microSD Card is perfect but since the update my Xperia C4 cant read it and it says that the MicroSD Card is damaged, which is totally wrong.
Yeah I am transferring apps, which occupied bulk space on my internal in built memory, but while unmounting these apps the transfer process remain idle on 2 %.Again I have also got to see a memory update available where this updation is also getting failed after many efforts.
It says memory card is corrupted.
So i bought a new one, sandisk 64gb, and the same message shown.
Please repair immediately
Me to!
I also!
I was hoping that this problem will be corrected or at least will tell what to do with the 64 gigabyte card.
Return the old update, or fix the work of SD this update did nothing better, just breaks the SD, then people form it and stay again with the idle. The most important things are silent, not notifications, not warnings, they just broke SD people and are happy, but I am very unhappy and displeased with the fact that no one cares about the quality of the update.
Me to!
Я тоже!
Я надеялся что эту проблему исправят или хотя бы скажут что теперь делать с 64 гиговой картой.
Верните старое обновление, или исправьте работу SD это обновление ничего лучше не сделало, просто ломает SD, потом люди её форматируют и остаются снова с неработающей. Самое главное молчат, не уведомления, не предупреждения, просто сломали людям SD и радуются, да я очень недоволен и недоволен я ещё более тем, что ни кто не заботится о качестве обновления.
