Where can I find the safe mode?
None of my files will be deleted?
It will disable any third party apps, once you restart the phone it should reenable the third party apps.
I already put my phone into safe mode but still can't receive call.
@Pinkheart, could you check your network settings? make sure they are the right apn settings. try to set your network type tp 3g/2g.
