C2305 not switching on
SOLVED
Gnair
Visitor
I bought this product online yesterday & used it just half a day & phew it went off. I tried switching it on back but in vain. It had updated to the latest build version via pc companion also. I have requested for  the replacement from the online retailer. Don't know how this happened.
14 REPLIES 14
Tejinder
Visitor
Disable Automatic Brightness.
Tejinder
Visitor
Almost all Xperias have this bug, if you enable automatic brightness your screen starts flickering with the change of angles of the phone. Nasty!
Gnair
Visitor
Ok done..
I will observe the set & will decide whether to go for a replacement.
Thanks for all the support.
Gnair
Visitor
Thanks I have disabled it.
Thanks for your support.
Chinmay_nanawar
Visitor
new c2305 is also facing such prblm.i was updating the new update 16.0.B.13 smething like tht which required computer so i did all as instructed  & after 15 mins the status of update was only 15% n thn i closed it n removed my phone frm tht my phone wont start what to do???
