Tiny pin hole on the screen
Najam23
Explorer
Hi
moved home and shifted tv in original packing however when switched back on I can see a tiny pin hole size dot on the screen illuminating light.
any suggestions to repair or mask the dot ? Thanks
3 REPLIES 3
HannahEd01
Community Team
Hey Najam23,
Are you sure it's an actual hole? Or a bright pixel? Try adding a photo so we can help you!
Also, where are you based? So I can provide the link for the nearest service centre. UK? Or IE?
Najam23
Explorer
Hi Hannah
Thanks for reply , when I touch it I can feel it’s like the outer surface scratched and therefore the bright light spot is showing. Please see the tiny dot on the photos. I am from Bracknell UK.
Piscie
Community Team
Hey @Najam23, if it's a dead picel, maybe it can be sorted out by performing a factory data reset, you also need to check if your TV software is up to date or not.
If not and you can feel it's a scratch, then you can contact the repair centre directly to arrange a repair service for you.
