Hi, I have a KD-49XG83 TV. I have noticed that there is a sight backwards tilt on the TV and upon googling this found out that this is an intentional 15 degree tilt for when the TV is on a corner unit lower than your seating position to give you the correct viewing angle on the TV.
My issue is that my corner unit is not lower than my seating and therefor because of the tilt I'm viewing the TV from an angle.
Is it possible to adjust the tilt to get the TV in a neutral angle?
15 degrees? are you sure? My own A1 that is tilted by design has only 6 degrees....
I only going off this article. Mine might not be one of the tvs this refers to but mine deffo has a tilt. https://www.sony.co.uk/electronics/support/articles/00166676
Any body know if this tilt can be adjusted?
