profile.country.AE.title
khaeid2
Member
Tasker on Android TV
I have some issues with my Android TV that I think Tasker can help solving some. is anyone around here using Tasker with the Sony Android TV?
3 REPLIES 3
Jimbobleics
Explorer
  • Yes I am
khaeid2
Member
good, I am starting to do that, but not getting good results.
what are you trying to do with it?
my main demand is to be able to open the digital audio output level control window, which I am not being able to do it so far
Jimbobleics
Explorer
I have set up my google home to trigger the google assistant on the tv so I don't have to press the button on the tv remote. Also I can ask my google home to locate someone and it opens google maps with their location. And if someone tries to unlock my phone it takes a photo and displays it on the tv automatically. The only way you can achieve what you are trying to do is with autoinput or adb shell with key presses I think.
