Sound problem
Crescent1
Explorer
Sound problem
I have a Sony android tv kd49xh8096bu and Sony sound bar ht-zf9. Added to this I have a sky q box.
the problem I have is the sound seems to switch from stereo to mono, not all the time but enough to make it irritating.
I can also describe it as the sound coming from the sound bar to then coming from the tv speakers.
also the info bar keeps dropping whilst this goes on, I fixed that by stopping the info bar in settings.
the tv is 5yr old but still within warranty (John Lewis) the sound bar is less than a year
any help would
14 REPLIES 14
Joe_Dohn
Specialist
Could you possibly let us know what they report to you? It'd be really helpful.
Crescent1
Explorer
will do. Thanks for your help
Joe_Dohn
Specialist
@Crescent1 Any updates on this my friend?
Crescent1
Explorer
Not really. The repair shop had the tv for a week and could find no problem. They hooked it up to their surround system which was different to mine.
they blamed my SkyQ for causing the trouble saying they have had numerous faults caused by the box.
not too sure where to go from here
Win_88
Specialist
When you get the TV back, try removing the Sky box and see if the issue happens without it. If it doesn't, there could be merit to you were told.
