Sony A8H - Control old Sony amp
EArazi
I was wondering if there's anyway of getting the Sony remote to control my old Sony str da-1200es amp. The amp doesn't support ARC.
My setup.
Sony A8H
Sky Q
Fire TV
Sony str da-1200es
The remote can control my sky q and fire tv,
I've even reprogramed the Netflix button on the remote using button mapper to open a different app.
Just need a way to control the amp, any ideas?
I do have a harmony hub and remote which can control it all but I really like the way the Sony remote knows what I'm on and auto switches the buttons to control the active device.
2 RÉPONSES 2
Joe_Dohn
Spécialiste
I don't think the amp supports Bravia Sync/Control for HDMI. I tried checking the Manual and there's not a single mention of that, so possibly out of luck on that front unfortunately.
EArazi
It certainly doesn't support s nc control via hdmi.
Only way I think I might be able to achieve it is using button mapper to call a reset api and then using something like the harmony api to send the IR commands from its hub.
Seems a bit of a faf.
Surprised Sony didn't include in the remote the ability to program and send infrared as the remote can send infrared and does for stuff like the TV power button
