KD85XH8096BU Unable to change Aspect ratio , screen menus greyed out
sttucke32
Explorer
Hello I have a 2020 Sony 85 inch KD85XH8096BU , and on any input, TV, streaming or blu ray input the screen menu shows locked in 4:3 , when playing modern blu rays or UHD DISCS I do display in 16:9 ok but with older films that are filmed in 4:3 I would like to stretch the image to remove left and right black bars, but I’m not able to do this as the wide menu, screen menu etc are all unavailable. Anyone know how to resolve this annoying feature? I understand that distortion and picture detail on the upper part or lower part of the image maybe lost but I would like the choice all the same. Please help? Many thanks Steve.
22 REPLIES 22
Win_88
Specialist
This is normal on Sony TVs. The aspect ratio settings can't be changed on all sources. It depends on the source you're watching really.
Win_88
sttucke32
Explorer
Hi there thank you for the reply, well this is interesting I spent 30 minutes on the phone today with Sony who seem blissfully unaware of that, can you suggest under what circumstances this menu would be able to be manipulated please?
I have a Sony engineer arriving tomorrow to also try and resolve this conundrum so that’ll be interesting!
Cheers
Steve
Sent from my iPhone
Win_88
Specialist
Do let us know how it goes.
I'm not sure exactly, I think it's something to do with the signal format. Can you adjust the ratio from the player settings?
Win_88
sttucke32
Explorer
Hi guys
So the technical support guys from Sony support determined that this needed further investigation. As a consequence they arranged under warranty for a Sony technician to visit my home today to take a further look at the problem. He arrived earlier today and has confirmed that the screen menu under the display menus is greyed out and regardless of the input to the tv the menu remains greyed out which isn’t correct. The root cause is either a software issue and/or a main psb fault but the latter is an unlikely cause. He is reverting to Sony directly to determine best next steps and will advise ASAP but he did say if there are many Sony customers that all suffer similar issues it is more likely that Sony may address the issue more urgently, so has anyone else raised the issue with Sony ?
Cheers and a Merry Christmas!
Steve
Sent from my iPhone
alish-
New
I have the same problem, you cannot change the aspect ratio as it is been grayed out no matter what, my TV is KD75XH7505
sttucke32
Explorer
Yes I am suffering the same problem, my dealer changed the main board though I’m not sure why , still the same problem, Sony needs to fix this
Best regards
Steve
edited[personal details removed]
Sent from my iPad
HannahEd01
Community Team
Hey, alish- do you have the same exact issue as the original poster? Aren't you able to change the aspect ratio on any source? Also, what's the software version on your TV? Press the Help button to get it. Another thing, are you sure about the model??
Steve, what did the Sony engineer do?
2939andy
Explorer
Hi and yes same for us on our XH9505 - all greyed out on HDMI 1 so we cannot adjust to expert advised settings - all very annoying. Tried Ariel input and some but not all greyed out.
Hope we can get them to fix this and thanks for raising it.
HannahEd01
Community Team
Hi 2939andy, this is the normal case anyway on Sony TVs I'm afraid, the aspect ratio doesn't work on all inputs.
