kd55xh8096bu
ChrisDFC30
New
kd55xh8096bu
Since the last update on kd55xh8096bu the sound has been out of sync and everything is unwatchable  anyone else having this issue?
3 REPLIES 3
Have you done a factory reset after the update?
If not I would recommend to do so.
ChrisDFC30
New
Why would I need to factory reset though?
Wouldn't that just erase everything I have on the tv and then make me reinstall the same update?
royabrown2
Hero
@ChrisDFC30
Yes, it will erase all your settings on the TV.
No, it won’t make you reinstall the same update, as this will survive the reset.
(If you think about it, if updates got deleted, it would bust the software right back to the model year you bought the TV from).
My favourite bedtime reading is a Sony product manual…
