urban_json
Explorer
KD-49X8307C Problem
the remote sometimes does not work after putting on th TV, need to unplug the TV. Any idea what to do ?
3 REPLIES 3
Anonymous
Not applicable
Hi there
A couple of things to try first.
  1. Replace the batteries
  2. Ensure you have the latest firmware installed - latest version is: PKG2.645.0052EUA
  3. Factory reset the TV, after you have the latest firmware installed.  See HERE
Cheers
dunanoir
New
I also have this issue.
However on reset I then have to reselect my wifi and re-enter the password.
The wifi issue also occurs intermittantly.
I've done the diagnositics and have even disabled the PS4 from starting the TV as this is when I first noticed it but it is really getting frustrating.
I can't say I've ever had a TV that just refuses to turn on from standby before and after convincing a family member to get the same TV before I knew of this I am dreading the "what the hell" phonecalls as in his case the powersupply is not that easy to get to.
Any updates Sony?
Tags (3)
Anonymous
Not applicable
Hi there
The two issues you have are known problems that others have reported.
Remote:
https://community.sony.co.uk/t5/televisions/2015-android-tv-bugs-and-issues/m-p/2148608#M42563
Network issues:
https://community.sony.co.uk/t5/televisions/2015-android-tv-bugs-and-issues/m-p/2148553#M42555
In regards to your network/wifi issue, can you please post with all relevent details in this thread? :
https://community.sony.co.uk/t5/televisions/android-tv-wifi-and-ethernet-issues/m-p/2147686
Cheers
