eARC Issues on X900H (XH90)
daylerees
New
Hi all,
Recently installed the latest update on my new Bravia (loving the TV) and enabled eARC (direct to a Yamaha RX-V6A) and now I find that sometimes when I turn the TV on there's no sound output.
I can "fix" the issue (for that session) by swapping the audio output from PCM to Auto 1 and back to PCM again.
Reporting in case others are experiencing this issue.
25 REPLIES 25
Win_88
Specialist
Hi @denorx
Have you tried switching Dolby Digital Plus  to Dolby Digital? Some ppl said that works for them as a workaround.
Win_88
profile.country.FI.title
tiizei10
New
I have tried that and many other options that are available. Switching to DD only doesn't completely fix it. Instead of 30 minutes until the sound goes off it works for an hour or so.
Win_88
Specialist
In that case, the best thing to do would be to contact Sony support as each individual case reported brings us closer to a solution.
Win_88
Dcalladine
Explorer
Bought this TV a few days ago and have an eARC Sony HT -X8500 sound bar attached via HDMI. Sound drops for a few seconds when I'm using the eArc function. This seems to only happen when streaming Netflix or Disney etc. I resorted to turning off the eARC and just using ARC.
kamal93
Explorer
Hello guys this is my first post
i have Sony 85 inch KD85XH9095B  connected Arcam AV40 for surround sound Processor
Both these have eARC
I am have eARC issue
1 when SKY box is set Dolby digit out
the sound returning back to Av40 via sony tv is slow motion , more like techno robotic   but most weird thing is if I switch eARC  off on the TV the sound lets DD PLUSE to AVR
2 eAR. mode on sound returning from my Blur ray dvd will only allow  3.2.1 but will not allow 3.4.1
I have the most up to date HDMI cable I have even tried optical HDMI
I am sure some thing is wrong with Sony tv software  - i checked and the software for this tv is up to date
can someone please help
HannahEd01
Community Team
Hi kamal, can you mention the software version that you are on right now as i have the same TV with a sonos surround system that is working fine with version 6.1554.
