disable automatic wifi connection
f6dqm1
Member
Hello. In a Bravia TV, is there a way to disable automatic Wifi connection at restart of the TV ?
2 REPLIES 2
LightFoot
Specialist
Hi @f6dqm1
Highly unlikely as TVs don’t normally have a “save password” box. You could always forget the network in the settings before switching off, which would work but not a real solution.
Is there nothing you can do at the Router end with the MAC address.
What is the full model number of your TV, it will start with KD or XR.
f6dqm1
Member
My sony is a KD-32W800. Before I switch off the TV (not stand-by, completly off), the Wifi switch setting is always OFF but, when I restart the TV, this switch is always ON. The latest state of this switch seems to be not memorized.
