- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Update to A7M3 Firmware from 3.10 to 4.0
Hi, Has anyone tried to update their A7M3 to the latest Firmware version? I have tried to follow the on line user guide for the update and it always fails. The guide suggests turning the camera off and removing the battery and then re-launching the Updater App. After the 4th attempt with different USB cables I have stopped trying until I get some feedback from Sony or other users as to their experience? Has anyone tried this yet?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,
Are you using the original USB cable that has been supplier with your camera?
If not, please do so.
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hey, make sure you check the instructions on the update link as many missing steps will cause this: https://www.sony.co.uk/electronics/support/e-mount-body-ilce-7-series/ilce-7m3/software/00257836
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, thanks for the advice, but, having followed the instructions and tried all the suggestions for correcting the problem, I have not been able to perform the update. I will next try the Sony support directly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I updated mine yesterday. Followed the instructions here and it was straightforward, even though I did not use the cable that came with the camera.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi luciano,
I am having the same problems and have tried 6 usb cables and the one that came with my camera. The camera connect to my PC except on the Mass Storage setting.
Have you found a fix to this?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
In the meantime, if you do find the answer, please let me know
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Luciano.o,
I have been having emails from Sony and they keep saying the problem is with my USB drives which I don't believe. I still think it's a Windows 10 problem.
I tried the update on a friends old laptop with Windows 7 and update installed with no issues at all in about 10 minutes!
I will keep trying with Sony and let you know my findings
jono
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have tried this multiple times with the original USB lead with no success and have now given up.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
