Imaging Edge on Mac OS 10.11.6
brice_kippertie
New
This OS is no longer supported by imaging edge. I have tried installing but the installer hangs indefinitely when it 'checks compatibility'.
Is there a backdated version of the app?
I'm hoping an old version will still work with the A7R II and ZV-1.
Thanks,
Brice
4 REPLIES 4
Hi Brice,
Usually a newer software should be backward compatible. Unfortunately I'm not aware of any older software.
Please reach out to Sony support - probably they can help.
Cheers
Win_88
Specialist
I don't think Sony makes older versions of their apps available to download. Not sure if you can find them hosted elsewhere online though.
brice_kippertie
New
Thanks for your help all the same. I will contact Sony.
alansumm
Explorer
Hi,
the latest version works for me on 10.11.6
I think I had the same installation problem and had to 'Allow apps downloaded from: Anywhere' under System Preferences / Security & Privacy / General
Alan
