- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Can I vew images on my camera with my Windows laptop?
I have a Sony Alpha 1 and yesterday I was at a studio and the owner was able to view the images on my camera using her iPad so that my model had a better idea of which ones she wanted.
I am able to connect my Windows 10 laptop to the camera using bluetooth, but cannot find any way to use this connection for anything, so what is the point?
I also tried downloading Imaging Edge Desktop and it seems that this cannot use bluetooth so I had to connect the camera to the laptop using a USB cable.
This does enable me to control the camera settings from the laptop using Imaging Edge Remote, and presumable take photographs.
However I cannot find a way to use the Imaging Edge Viewer to access images on the camera but not on the laptop.
Is there a way to view images which are still on the camera using Imaging Edge Desktop, or do I have to physically transfer the photos onto the laptop to view them at a reasonable size?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Bluetooth in this camera is used for RC operation, check this out:https://helpguide.sony.net/ilc/2040/v1/en/contents/TP1000425296.html?search=bluetooth
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks, none of Sony's software is of any use, but it seems that just connecting the camera to the laptop using a USB cable enables Windows to see the files on the camera and view them or copy them to the computer.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You can try to connect the camera to your smartphone ( imaging edge mobile) and then transfer them to your windows via BT.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks, I did discover how to view the images on my phone, but am happy that I can view them on my laptop by connecting with a USB cable and using file explorer, which is much simpler than trying to get Sony's software to do the job.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes, that was the first thing I tried, as I mentioned in my first post on this topic.
